System requirements for i-doit v38
Hardware
Minimum requirements (GNU/Linux)
| Component | Value |
| CPU | 2 vCPUs |
| RAM | 2 GB |
| Disk | 10 GB free |
| Capacity | Up to approx. 10,000 objects, 10 concurrent users |
Recommended configuration
| Component | Value |
| CPU | 4 vCPUs |
| RAM | 8 GB |
| Disk | 50 GB free (fast storage recommended) |
| Capacity | Up to approx. 500,000 objects |
Performance: i-doit is a database-intensive application. Fast storage (SSD/NVMe) significantly impacts overall performance.
Software stack (LAMP)
| Component | Supported versions | Recommended |
| Operating system | GNU/Linux 64-bit, Windows Server 2022 | Debian 12, Ubuntu 24.04 |
| Web server | Apache 2.4 | Apache 2.4 |
| PHP | 8.2 (deprecated), 8.3, 8.4 | PHP 8.4 |
| MariaDB | 10.6, 10.11, 11.4, 11.8 | MariaDB 10.11 |
| MySQL | 5.7 (deprecated), 8.0, 8.4 | MySQL 8.4 |
Required PHP extensions
bcmath, ctype, curl, fileinfo, gd, imagick, json, ldap, mbstring, memcached, mysqli, mysqlnd, pgsql, session, soap, xml, xmlwriter, zip
Browsers
Current and previous version of:
- Mozilla Firefox (incl. ESR)
- Google Chrome / Chromium
- Microsoft Edge
- Apple Safari
Update path to v38
- From version 35: Direct update to v38 possible
- Version 30-34: First update to v35, then to v38
- Below version 30: Sequential update required
Add-on compatibility
When updating to v38, minimum versions are required for add-ons:
| Add-on | Minimum version |
| API | 2.3 |
| Documents | 1.10 |
| Flows | 1.2.0 |
| ISMS | 1.6.4 |
The complete compatibility matrix can be found in the Knowledge Base.
Detailed documentation: System requirements in the Knowledge Base
Comments
0 comments
