Known issues when updating i-doit
This article documents known issues that may occur when updating to or from specific i-doit versions, along with their solutions.
Before updating
The following points should be checked before every update:
- Create a backup — fully back up the database and file system
- Check system requirements — verify PHP, MariaDB, and Apache versions against the target version compatibility matrix
- Check add-on compatibility — many add-ons have minimum version requirements per i-doit release
Ensure write permissions — the web server user (e.g.
www-data) needs write access to the i-doit directory
Updating to version 38
Add-on minimum versions
When updating to v38, numerous add-ons must be updated to minimum versions beforehand:
| Add-on | Minimum version |
| API | 2.3 |
| Documents | 1.10 |
| Flows | 1.2.0 |
| ISMS | 1.6.4 |
Add-on ZIP files are available for download in the customer portal. Installation is done via the Admin Center under Add-ons > Install/update module.
Gateway Timeout during migration
Symptom: The update aborts with a "Gateway Timeout", especially on large installations.
Cause: Large logbook tables significantly slow down the database migration.
Solution: Timeout errors during logbook migrations can generally be ignored — they are not critical for operation. Run the update again. If the problem persists:
- Increase Apache/Nginx timeout values
- Run the update via Console (bypasses browser timeouts):
sudo -u www-data php console.php update \
-u admin -p admin \
-z /path/to/idoit-38-update.zip \
--v 38
Add-on & Subscription Center does not load
Solution: The server must be able to reach the following addresses:
crm-gateway.i-doit.comlizenzen.i-doit.comcenter.i-doit.com
Adjust firewall rules accordingly.
Updating to version 37
HTTP 500 / blank page after File-Update
Symptom: When updating from version 36 to version 37 or 38, the update aborts at step "4. File-Update" with an HTTP 500 error, or i-doit shows only a blank page on every request afterwards. Updating from version 35 to 36 works without issues.
Error message in web server log:
PHP Fatal error: Uncaught TypeError: Cannot assign null to property isys_tenant::$description of type string in .../src/classes/core/isys_tenant.class.php
Cause: On installations originally created with older versions, the tenant description in the database can be NULL. As of version 37 the corresponding property is strictly typed as string, so PHP 8 rejects the NULL value and every request (including the update wizard) ends with a fatal error.
Solution: Set the empty tenant description to an empty value. Please create a backup beforehand. The affected table is in the system database (default idoit_system); adjust the user and database name in the following command accordingly.
mysql -u idoit -p idoit_system -e "UPDATE isys_mandator SET isys_mandator__description = '' WHERE isys_mandator__description IS NULL;"
After running this, login and the update work again. If a similar message appears for another field afterwards, contact support.
Updating to version 35 (from version 34)
Crypto hash migration fails
Error message:
Fatal error: Uncaught ArgumentCountError: 4 arguments are required, 2 given
in migrate-system-crypto-hash-to-tenant.php:28
Solution: Install the hotfix i-doit_34_ID-11978_migration-of-crypto-hashes.zip on version 34 before updating to version 35. The hotfix is available in the Knowledge Base hotfix archive.
Updating to version 34
HTTP 500 after update (SM-View add-on)
PHP Fatal error: Declaration of
Symfony\Component\HttpFoundation\ResponseHeaderBag::all(?string $key = null)
must be compatible with
Symfony\Component\HttpFoundation\HeaderBag::all(?string $key = null): array
Cause: SM-View 2024.3.0.2708 is not compatible with i-doit 34.
Solution: Deactivate the SM-View add-on in the Admin Center until a compatible version is available.
Updating to version 33
Functions disappear after update
Symptom: After the update, functions such as the update function itself or the LDAP configuration are missing.
Cause: Placeholder variables in the configuration file were not correctly replaced with values during the update.
Solution: Check and correct the following values in the file .../i-doit/src/config.inc.php:
Correct:
$g_enable_gui_update = '1';
$g_is_cloud = '0';
$g_active_features = [''];
Incorrect (placeholders not resolved):
$g_enable_gui_update = '%config.admin.enable_gui_update%';
$g_is_cloud = '%config.cloud.active%';
$g_active_features = ['%config.active_features.list%'];
Updating from version 28
"Next" button does not work after hotfix
Symptom: After installing hotfix i-doit_28_hotfix_ID-10745.zip, the new version is displayed but clicking "Next" does nothing.
Error in browser console (F12):
Uncaught ReferenceError: open29NoticeHandler is not defined
Solution:
- Run the update to version 28 again using the updater
- Download the version 29 update ZIP from the customer portal
- Extract the ZIP in the i-doit directory
- Run the update to version 29 using the updater
Updating from version 25-28
Updater shows incorrect target version
Symptom: The updater shows v30 as the next version, when v29 would be correct.
Solution: Manually download the v29 update package from the customer portal and extract it in the i-doit directory.
General issue: "A problem occurred during update" during File-Update
Cause: Missing write permissions on the file system.
Solution by operating system:
Debian/Ubuntu:
cd /var/www/html/
sudo find . -type d -exec chmod 775 {} \;
Red Hat Enterprise Linux:
cd /var/www/html/
sudo chown apache:apache -R .
SUSE Linux Enterprise Server:
cd /var/www/html/
sudo chown wwwrun:www -R .
After the update
- Clear cache: Browser cache (Ctrl+Shift+R) and i-doit cache (Administration > System Tools > Cache)
- Update reports: Administration > System Tools > Cache / Database > Update reports
- Rebuild search index:
sudo -u www-data php console.php search-index -u admin -p admin
Detailed documentation: Installing an update | Known update problems
Comments
0 comments
