Securing the i-doit web interface (HTTPS)
Setting up HTTPS
For secure access to i-doit — especially over the internet — HTTPS should be configured.
Apache VHost configuration
In the Apache VHost file (e.g. /etc/apache2/sites-available/i-doit.conf):
<VirtualHost *:443>
ServerName idoit.company.com
DocumentRoot /var/www/html/i-doit
SSLEngine on
SSLCertificateFile /etc/ssl/certs/idoit.crt
SSLCertificateKeyFile /etc/ssl/private/idoit.key
</VirtualHost>
<VirtualHost *:80>
Redirect permanent / https://idoit.company.com/
</VirtualHost>
Then restart Apache:
sudo a2enmod ssl
sudo a2ensite i-doit
Internet access
If i-doit should be accessible from external locations:
- HTTPS is mandatory — API keys and credentials are otherwise transmitted in plain text
- Use a reverse proxy (e.g. nginx) for additional security
- Configure firewall rules so only required ports (443) are open
- Consider VPN as an alternative to direct internet access
CSRF token (from v38)
From i-doit v38, CSRF token protection is configurable. The setting is located in the Admin Center under System Settings > Security > CSRF Token.
Detailed documentation: Security and protection in the Knowledge Base
Comments
0 comments
