How do I create a custom object type group?
Object type groups structure the main menu of i-doit. By default, there are groups such as Hardware, Software, Network, etc. Custom groups can be created as needed.
Creating a new object type group
- Navigate to Administration > Data Structure > Edit Data Structure
- Click the "New object type group" button next to the existing groups
- Enter a name for the group
- Assign the desired object types via drag & drop
- Save
The new group will then appear in the i-doit main menu.
Tips
- Object types can be moved between groups
- Empty groups are not displayed in the menu
- The order of groups in the menu can also be adjusted via drag & drop
- The permission system can control which user groups are allowed to see specific object type groups
Detailed documentation: Object types in the Knowledge Base
Comments
0 comments
Article is closed for comments.
