What are unfinished objects?
Unfinished objects are created in i-doit when a new object is initiated via the New button but not saved — for example, because the browser was closed, the page was left, or a session timeout occurred. Clicking Cancel also creates an unfinished object.
Why does this matter?
Unfinished objects occupy object IDs and may count toward the license. A large number of unfinished objects can affect the available object count.
Cleaning up unfinished objects
There are two options:
- Manually: Navigate to Administration > System Tools > Cache / Database and run the cleanup for unfinished objects
2. Automatically: A cronjob can perform the cleanup on a regular basis:
sudo -u www-data php console.php system-objectcleanup --objectStatus 1
Set up a daily cronjob for automatic cleanup to avoid license issues caused by accumulated unfinished objects.
Detailed documentation: Life and documentation cycle in the Knowledge Base
Comments
0 comments
Article is closed for comments.
